Ir para o conteúdo principal
Quinta Geração do Iphone. A Reparação deste dispositivo é correta, requer ferramentas especificas e paciência. GSM/CDMA/16, 32 OR 64 GB/Black or White.
2193 Perguntas Visualizar todos
Why is my backlight on, but not my screen?
I am attempting to repair a friend's iPhone 4s to no avail, and I need some help. I have restored it in an effort to rule out software malfunctions, and have installed several screens which appear to be in working order, however the screen continues to be blank, although the backlight is working on each display when it is attached. The phone appears to be in good working order, but for this one small error (it is recognized on a computer, holds a charge, etc). Here is a link with a picture of the one abnormality I have located thus far - a screw socket is missing on the main board near the display connectors https://docs.google.com/file/d/0B6WmvtP7...
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
you probably didn't take out the protector covering the LCD when you got the new screen. hopefully this will help you
Esta resposta foi útil?
Pontuação 0
Ryan Hoffman, check the component pointed to by the red arrow. On your attached image, it appears to be damaged. Use a multimeter to check it for continuity. Also, take a closer look at the area outlined by the black rectangle. There are a few SMD components that may have gotten damaged. Of course, all of this may just be based on my poor eyesight:-)
Pontuação 0
1 comentário:
Hi did you get this problem sorted, I have the exact same problem and damage to 4s Logic board.
por
Adicionar a sua resposta
Ryan Hoffman será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 247
