HOw to fix the cooling fan?
My fan stopped working and I want to fix it !!!!
Esta é uma boa pergunta?
Cancelar
15.6", Intel HD Graphics, Core i3 2330M, Windows 7 Home Premium 64-bit, 4 GB RAM, 500 GB HDD
Rep: 1
Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
Visite Nossa LojaAbaza, I just added the manual to the device page. Go to this page. Scroll down to the bottom, you should see the Document headline, right below it is the link for the service manual. Download that, on page 75 an on is what you are looking for. Hope this helps, good luck.
Rep: 1
try updating the BIOS if it doesnt work then put some pressure air on the fan and ventilation inlets and clean the dust off from the fan if it also doesnt work then take a small pin and put it in the fan and try to move the fan manually by supporting it with the pin your fan will definatly start working again if it also doesnt work then you should replace the fan. it worked for me :)
Try entering the bios first to see if their is a diagnostic tool to detect faulty Hard ware.
I assume the fan just fried and died, so you are going to have to replace the heatsink/fan.
This takes a bit of skill and mechanical ability. Assuming a faulty fan You will have to:
1. get a replacement fan/heatsink for your laptop
2. take the old heatsink/fan off
3. put the new heatsink/fan on.
Comentários:
It doesn't work
por Gbenga Timothy
It doesn't work wen i changed the fan/heatsink
por Gbenga Timothy
Últimas 24 horas: 2
Últimos 7 dias: 16
Últimos 30 dias: 89
Todo: 11,585
