Ir para o conteúdo principal
Quinta Geração do Iphone. A Reparação deste dispositivo é correta, requer ferramentas especificas e paciência. GSM/CDMA/16, 32 OR 64 GB/Black or White.
2193 Perguntas Visualizar todos
Where to buy a Logic/Motherboard Replacement
Hello all,
Can anyone help me with this, I recently replaced a battery on my 4S the battery went in fine (something I've changed plenty of times before).
This time however when turning it all back on the phone never found signal again, I tried everything I could think of and checked all the connections which seemed fine but still no luck. I took it to a local repair shop and they tried a few things and said somehow I'd blown a chip on the motherboard and it was basically knackered!
They tried something called re boiling the chip and this didn't work and told me nothing else could be done.
Is it possible to get a full replacement logic/motherboard and if so where and are they expensive??
Also has anyone else had this issue??
Thanks in advance
Si
Esta é uma boa pergunta?
Pontuação 5
Adicionar um comentário
6 respostas
Solução escolhida
Si, PowerbookMedic has some used ones as well as ebay.com. These are used and the cheapest one is $250. New ones are available from places like alibaba.com Cost for those is $360 and up. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 3
1 comentário:
I would go with PowerbookMedic, they have a good reputation where as you might end up not getting what you expected from an e-bay seller.
por
In the market, you just buy the USED one. If you want, please let me know.
Pontuação 2
3 comentários:
any one help me where i purchase motherboard fo i phone 5s
por
hi , i need a used motherboard for my iphone 6 64 gb variant.
Please send your contact no on nbsteam7@gmail.com.
i will surely get back to you.
por
Any wana intersted for buying all iphones used mother bord ,logic bord. Please contect my email
sharmajimaharaj1975@gmail.com
por
Did u get it changed? If so, help me Im having the same problem
Pontuação 0
Yes, I have bought the Motherboard Replacement and new phone's on that site. Really cheap and high quality for the step price. All the |phones accessories| and find it values more than you paid.Freeshipping at Wholesale Price. Great one.
Pontuação 0
1 comentário:
in which site?
por
It sounds like the unit was still powered on when you replaced the battery. When you pull the battery connector, (while it's still hot) it causes the first capacitor and IC in line to blow out. Replace the cap and IC. AFAIK.
Pontuação 0
my motherboad is dead
Pontuação 0
Adicionar a sua resposta
Si será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 26,180
