Ir para o conteúdo principal
Lançado em abril de 2010 / processadores Core i5 de 2,4 ou 2,53 GHz ou Core i7 de 2,66 GHz
MacBook Pro is just dead
My Macbook Pro does not start (boot) anymore, no sign of life at all.
What I tried so far:
1. pressing the power on button in various combinations with the cmd, ctrl and shift buttons (as suggested on some websites)
2. removed the battery, pressed the start button for at least 10 seconds and replaced the battery
3. removed the battery and tried to start without battery (but with the battery charger connected)
Doing a battery check (pushbutton at the left side) rusults is no leds lighting when the battery charger is disconnected and all leds lighting when the battery charger is connected.
Any help is appreciated,
Rik
Esta é uma boa pergunta?
Pontuação 4
2 comentários
A history of the machine might help.
por
the macbook worked fine for years, some days ago I left it in working order, when I returned one hour later it was dead.
por
Adicionar um comentário
3 respostas
Solução escolhida
Knowing the exact year/model would assist us with getting specific info for you.
Check the power adapter voltage with a meter. Perhaps it has failed.
Can you borrow another adapter or charge the battery in another MacBook ?
Esta resposta foi útil?
Pontuação 4
25 comentários:
I tried another adaptor without any result.
The model is A1286, year 2010.
por
Rik. Thanks for accepting my answer but its a little premature if you are not up and running. Now I have the model no ill see if I can't give you more specific advice. Are you willing to put your Mac apart to investigate?
por
Ok, I "unaccepted" the answer.
As long as it can be reversed I am willing to disassemble the Macbook.
Thanks, Rik
por
do you have a multi meter or can you borrow one?
por
yes, I have a multimeter
por
Exibir mais 20 comentários
Did your MagSafe only light up with a dim green light?
Mine shows only a dim green light with the battery in or just the AC. The battery lights are all off. Do you think your fix would work in my case?
Pontuação 3
1 comentário:
I had no LEDs lighting when running only on battery and all LEDs lighting when running on the AC power supply.
But if you have the screwdrivers, the resistor and a voltmeter at hand it takes less than half an hour to try it.
por
Anyone else in this situation can try this, to verify if the battery is the culprit (on older Mac models with removable battery):
https://osxdaily.com/2019/06/14/how-boot...
Pontuação 0
Adicionar a sua resposta
Rik será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 10
Últimos 30 dias: 23
Ao todo: 4,091
