Ir para o conteúdo principal
Laptops PowerBook G4 Aluminum com telas de 12 polegadas. Lançados em 2003 pela Apple.
Why is the screen dim?
I just took it apart to remove a loose screw in the optical drive and now the screen is dim...did I disconnect something? I am also having trouble getting the keys back on (is it a coincidence that one of the keys I removed was the dimmer key and the other is the brightener key)
Esta é uma boa pergunta?
Pontuação 1
4 comentários
are you saying that you cannot increase brightness because the key is not working?
por
Thanks for the tips, I tried an external keyboard and proved that the problem is not the keyboard. I think I might have tweaked the display cable when I was putting the computer back together or maybe I mixed up some of the screws, could a too long or too short screw cause a problem?
por
DEAR LEMERISE..THE screen is very dark...if I turn it at a particular angle I can see the icons,etc on the screen.
por
12"...I've ordered a new display cable and when I get it i'll recheck all of my screws to make sure they are the right ones in the right places..thanks for your advise
por
Adicionar um comentário
5 respostas
Solução escolhida
You may go to the system preferences display preferences and check if you can modify the brightness from there. If yes then the keyboard has a problem. Try with an external USB keyboard.
Esta resposta foi útil?
Pontuação 2
try turning up the brightness, also charge your battery, the screen dims when the battery lowers, you could try to check the display cable too.
Pontuação 0
What is the PowerBook model (speed) ? 12"/15"/17" ?
Pontuação 0
You still have video in the screen so the new display cable will not solve the problem. From your description it seems to be a lightning problem related to the inverter cable, inverter board or backlight. You say the screen is dim. Is it completely black or there's still light in it ?
Pontuação 0
If the long screw you are referring to pinches a cable it can cause problems.
only YOU can tell if you put it together properly - why not take it apart and check - that way you also can check if you damaged a wire by routing it incorrectly.
Pontuação -1
Adicionar a sua resposta
oliviachas será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 35
Ao todo: 2,775
