Ir para o conteúdo principal
Um MP3 player de vídeo com tela sensível ao toque de 3,6" e 4 GB da Sylvania.
Why won't player turn on?
I have tried over and over again to turn my player on. I have tried charging it several times and have even tried the reset button, but it will not come on. It was working fine, then I started downloading some more music when it shut off and would not turn back on. My laptop recognizes that it is pluged up. I only have a USB cable to charge it and I have even tried three different USB ports on my laptop. What is the cause and fix for this problem?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
Solução escolhida
henryr79, it does sound like a battery failure. If it has discharged to below its threshold it will no longer accept a charge or hold a charge. I would start with that. Follow this teardown to change your battery and re-evaluate. hope this helps, good luck.
Esta resposta foi útil?
Pontuação 2
2 comentários:
What does a battery cost and where can one be bought?
por
Once you have it apart, there should be a number on the battery. Use that to do a search according to your location.
por
It was not working and how to fix it.
Pontuação 0
1 comentário:
Um... what are you talking about???
por
My sony walkman wont turn on
Pontuação 0
Adicionar a sua resposta
henryr79 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 20
Ao todo: 3,029
