Ir para o conteúdo principal
O Macintosh Power G4 faz parte de uma série de computadores pessoais de mesa lançados pela Apple em 1999, e postos à venda até 2004. Esta página é designada ao modelo M5183.
39 Perguntas Visualizar todos
Why does this computer not power up at all?
I have replaced the pram battery, power supply, and switch on this PowerMac G4 450 Mhz dual processor computer and still no power. Will a new logic board assure a fix or could it be the computer processor, ribbon cables, etc. causing this? I don't want to sink much more into this unless it is a pretty sure fix. Thanks.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Solução escolhida
ndwig , here is the way Apple suggest that you check this particular symptom:"
System is completely dead (no fan movement and power LED is not lit)
1. Verify the power outlet is good.
2. Replace the power cord.
3. Make sure the voltage switch on the back of the power supply is set to the correct
voltage.
4. Reset the logic board. Refer to “Resetting the PMU on the Logic Board” in this
chapter.
5. Check for trickle voltage on the power supply connector. Refer to “Power Supply
Verification” in this chapter. If verification fails, replace the power supply.
6. Disconnect external devices, including the monitor, and start up the computer.
7. Remove internal cards and start up the computer.
8. Disconnect internal hard drives from the logic board and start up the computer.
9. Check the modem connector. If the connector has any bent pins, replace the logic
board.
10. Check the pins in the power supply connector on the logic board. If the pins are bent,
replace the logic board.
11. Replace the logic board.
Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thanks. I'm pretty much to the logic board part of this.
por
Check and see if your CPU is switched to on
Pontuação 0
2 comentários:
@Mason Schmidgall, how do you switch the CPU to on?
por
Thanks for your input. I use the power button on the front of the machine try and power it up. There was a storm that put the power off here for just a few minutes. Ever since then the computer has not responded at all.
por
Adicionar a sua resposta
ndwig será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 607
