Ir para o conteúdo principal
Também conhecido como LG Splendor, uma encarnação do LG Optimus L7, por vezes conhecido como LG Snapshot ou Swift L7 sob os números de modelo US730 e LG730, dependendo da operadora.
I can't find a guide to replace screen
I've been searching all over YouTube and a couple of websites but i cant seem to find a guide for the LG Venice/Splendor, I've seen similar phones that LG manufactures which have the same repair steps, would this phone file under other phones in means of repair guides?
Esta é uma boa pergunta?
Pontuação 1
2 comentários
Much thanks :) i really appreciate the guide and response time thanks again :D
por
you are welcome. Best of luck to you and thank you for accepting my answer.
por
Adicionar um comentário
3 respostas
Solução escolhida
alcranking, try this:"
Take apart the battery cover using notch below
Imagem
Take apart the battery and remove screw (12 point)
Imagem
1. Unfastening the hook, make gap between Rear Cover and Front Cover
2. Widen the gap between Rear Cover and Front Cover and hook off starting from below side (back view)
Imagem
1. Take connectors & Side Key FPCB (1~9) out of the Main PCB
2. Widen the gap between Front cover and main PCB
Imagem
3. Remover the Bracket Camera to upper
Imagem
1. Unfastening the hook from below side, sh back side of LCD through a hole on back side of Front cover
2. Take apart Frame out of Front cover
Imagem
1. Lift LCD from the frame & Take off the LCD.
2. Be careful. Do not tear the LCD FPCB
Imagem
I always wonder about the grammar in service manuals :-) Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 4
4 comentários:
So this is a screen replacement guide for the LG Venice? Please correct me if I am wrong.
por
Jabran, yes it is
por
Hey old turkey, I am grateful of the pics you put up to fix the lg Venice, but could you please make a video, because I cannot understand the pics that we'll. if you could send me the video on my email that would be great. Husban_shahid_7@hotmail.com
por
Sorry Husban., I did finish the repair and do not have the phone anymore.
por
Okay I follow just didnt remove the lcd I simply replaced the outer screen now I keep getting this black smudge on my screen do I have to remove the lcd or do I use loca
Pontuação 1
9 comentários:
depends on "the smudge", post an image and let us see what you see.
por
https://dl.dropboxusercontent.com/u/5441...
Here's a link to the images and no its not water don't know what it is when I go to remove everything to remove the screen it goes away
por
"when I go to remove everything to remove the screen it goes away" what exactly do you mean by the? right now it looks like air trapped between the digitizer and/or LCD.
por
When I go to seperate the frame from the back piece to get to the screen I guess it could be air
por
It does look like it creates a bubble underneath,
por
Exibir mais 4 comentários
Thank You :)
One more question: Do you recommend exchange by my self, or go truth an specialist. looks not complicated but I do know nothing about cellphones. looks like is just the glass screen broken but since this was broken because I press with the trunk of my car:( I do know if can be there another damage.
The other hand, I find a different options to by a screen replacement, since screen glass to digitizer and complete screen digitizer assembly? could be the last one a best option...I appreciate any tip to do it or not risk. Because I really want back my cellphone for personal reasons.
Thank You.
Pontuação 0
1 comentário:
Replacing the LCD will not affect your memory.
por
Adicionar a sua resposta
alacranking será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 16
Ao todo: 7,222
