Ir para o conteúdo principal
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
Random freezing and display fault
HI,
Recently I'm facing issue with my white MacBook (Early 2008) which is randomly freezing and a message shows that i have to turn off the machine. Sometimes during this freeze the display shows some sticky line or numbers or characters flickering.
Best Regards
Aryan
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Often when I see a system freeze up it's caked up with dust and likely needs to have the thermo paste re-applied. I would start with cleaning if the problem is still persists you may have to reformat the HD and re-install your OS & files (your HD maybe having problems).
Are you up to taking your system apart? Do you have the needed tools, ESD mat & wrist strap?
If you do follow this guide Upper case removal. Make sure to fully scrub down the logic board, heat sink fin from the back and fan with a soft brush. Using can'ed air blow out the junk. Follow proper ESD practices!
If the system is not that dirty you should consider pulling the heat sink off so you can apply fresh thermo paste onto the CPU & GPU to get better heat transfer as the old paste is most likely not doing a very good job any more (causing the fan to run hard). Follow this guide to Step 26 (you don't need to go all the way here) Logic board removal
Imagem de MacBook Core 2 Duo Upper Case
Guia
MacBook Core 2 Duo Upper Case Replacement
Nível de dificuldade:
Moderado
45 minutes - 2 hours
Imagem de MacBook Core 2 Duo Logic Board
Guia
MacBook Core 2 Duo Logic Board Replacement
Difícil
2 - 3 hours
Esta resposta foi útil?
Pontuação 2
3 comentários:
hi,
but this is not related to over heating or HD, its happening usually only when im moving it....
por
Your system was not designed to be moved about running, lid open (excluding sleep mode).
por
I would still do a good cleaning first as your system likely needs it do to it's age.
por
Adicionar a sua resposta
aryan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 142
