Ir para o conteúdo principal
Repair guides and support for Olympus digital cameras.
231 Perguntas Visualizar todos
Is there a way I can turn the Olympus E-P3 screen on/off?
One day the screen was black after i switched it on. The touch functions still works, i can take pictures touching the screen.
I can use the VF-1 optical viewfinder and it works as it should.
So everything works, except that the screen is black.
Is there a function i've missed where you can turn the screen on/off? (i've read the manual and can't find anything about this)
Can it be a loose cable as the touch is working, but not the image?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
umagon1337, it does not appears as if the LCD can be turned off on purpose. The E-P3 uses two separate ribbon cables on the display, so it is possible that you are having trouble with the LCD ribbon while the digitizer still works. At this point I suggest that you disassemble your camera and check for any loose connection. Take a look at the LCD, it appears as if you are needing a new one.
Esta resposta foi útil?
Pontuação 1
2 comentários:
Thank you for your answer. I guess i will buy the right tools and open it up as you say and hope it is just the one ribbon cable.
por
Sounds like a good plan, I hope it will work out for you. Thank you for accepting my answer.
por
Adicionar a sua resposta
umagon1337 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 269
