Ir para o conteúdo principal
The Nokia Lumia 900 is a Windows Phone 7.5-powered smartphone with 4G LTE support and a ClearBlack AMOLED capacitive touchscreen.
Can the screen be replaced without replacing the entire LCD?
Can the screen be replaced with changing the entire LCD assembly on the Nokia Lumia 900?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Pergunta mais útil
Lara, it is another one of those screen that is adhered together. It "might" be possible with the right tools, but definitely not something that a DIY'er has readily at home. I would suggest that you replace the complete assembly. Check on here for more information. My answer to this is, no. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Lara será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 2,314
