Ir para o conteúdo principal
Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
597 Perguntas Visualizar todos
Water damage to MacBook Pro 15 (A1286)
Hi, I am looking to repair a Macbook 15 (A1286), which had water damage. The issue is with display. The computer boots up, but the screen displays as a series of vertical lines. It will display fairly normally when connected to an external monitor. Apple tested the machine, said that the logic board was ok (but wouldn't guarantee that it would stay that way i.e.. may slowly corrode over time). What parts would I need to make this machine operational again? Cheers Jennine
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
3 respostas
Solução escolhida
"fairly normal" external display - anything other than normal hints at VGU (VGC) chip (logic board) damage. I would start with cleaning and replacing the data display cable (it's the least expensive and involved repair).
Good Luck.
If this Answer is helpful please remember to return and mark it Accepted.
Esta resposta foi útil?
Pontuação 2
Try using contact cleaner on the connections to the LCD?
Pontuação 0
I would take it to *apple* because they are the ones who made it. They could probably fix it. If you don't know where to find Apple, all you have to do is google their destination that is nearest to you at www.google.com
Pontuação -1
1 comentário:
Mary liquid damage is not a covered "repair" under Apple's (or most other electronic) warranty and remember this is the DIY repair forum...
por
Adicionar a sua resposta
jennine será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 1,085
