Ir para o conteúdo principal
An upgrade of the Nintendo Game Boy Advance, the Advance SP was released, in North America, on March 23 2004 with a square structure and clam-shell design.
20 Perguntas Visualizar todos
Why won't my GBA SP charge?
So here's my issue. Whenever I try to charge the device, the indicator light turns on for a couple seconds, then turns back off. I've noticed that sometimes if I bend the charging cable a certain way, it might start charging. But, it will not keep charging if I let go of it. Any ideas?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Jesse M, sounds to me like you already figured it out:-) "if I bend the charging cable a certain way, it might start charging. " I would start with a new charger and a new battery. If that does not work, I would then replace the charging jack. Hope this helps, good luck
Esta resposta foi útil?
Pontuação 3
probably the circuit board
Pontuação 0
Adicionar a sua resposta
Jesse M será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 5,501
