Ir para o conteúdo principal
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
20 Perguntas Visualizar todos
Broken screen and when turned on shows blank.
I a Samsung galaxy S3 it has a broken screen, but when its turned on it shows a blank screen. can it be that i have to change the digitizer and how much do you charge to repair ?
Esta é uma boa pergunta?
Pontuação -1
1 comentário
Jair, ifixit does not repair items. Here you can get great parts, tools and advice. The repair will have to be done by you.
por
Adicionar um comentário
1 resposta
Solução escolhida
I'm not sure what Ifixit charges but you're going to need to get the LCD/Digitizer assembly. It is EXTREMELY difficult if not impossible to separate the two and it will just look better anyway with the whole assembly. The parts can be found all over, especially on Ebay/Amazon. Should range from $150-$250. Hope this helps!
Esta resposta foi útil?
Pontuação 1
2 comentários:
thanks alot. Have a great one @oldturkey03
por
thanks Austin Harris, it sure helped.
por
Adicionar a sua resposta
Jair será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,560
