Ir para o conteúdo principal
Lançados no final de 1993, o Macintosh Quadra 610 e o Macintosh Centris 610 são dois computadores pessoais intimamente relacionados que fazem parte das séries Quadra e Centris de computadores Macintosh da Apple Computer, respectivamente.
Should I replace the Hard Drive?
Tried to troubleshoot and nothing happened,I inserted disk tools 7.5 and used disk doctor and It couldn't find the Hard Drive, Where would I find a new hard drive for this?
the one it has is (in my opinion) completely unreliable
please take a look at my other question too
thanks,
Esta é uma boa pergunta?
Pontuação 1
3 comentários
Are you getting three bongs on start up?
por Compartilhar
no, 1 bong it starts up, then sits for 5-7 minutes, then it just goes wild and I have to turn it off
por Compartilhar
Mayer, Your descriptions of your issues are exasperating. "Goes wild", tells me absolutely nothing. You're very hard to help. SO I'LL JUST LET SOMEONE ELSE TRY TO HELP YOU.
por Compartilhar
Adicionar um comentário
2 respostas
Pergunta mais útil
You'll probably need a new hard drive for it. Especially if the install floppy cant find the HD.
Your best bet would be to scour eBay for a replacement.
Also, if you've ever done any sort of hardware repair on a computer, you shouldn't have any problems replacing it. Those old macs were meant to be serviced.
Esta resposta foi útil?
Pontuação 1
Esta resposta foi dada inicialmente para uma outra pergunta.
You'll need a 1/3 height SCSI hard drive. This is just a standard size drive.
Pontuação 1
Adicionar a sua resposta
Ted Mayer será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 10
Ao todo: 529
