Ir para o conteúdo principal
Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745 Perguntas Visualizar todos
MacBook Pro Not Powering On (Possible Keyboard Cable Issue)
MacBook Pro 13" A1278 mid 2009
So, my brother gave me this MacBook Pro that his girlfriend had spilled wine on and ruined the keyboard and trackpad. It worked fine with an external keyboard & mouse, however I'm not about that life so I decided to purchase a new upper case. I followed the installation instructions, and everything went well except for these two things:
1) I broke off the subwoofer connector with the spudger. I thought I was moving the wire but I actually ripped off the entire housing that it slides into. Oops!
2) I CANNOT, repeat, CANNOT get that keyboard ribbon cable to slide in all the way. There's still some silver sticking out that I can see. I've tried pulling it in with scotch tape, pushing it in with my fingers, pushing it in with an eraser, leveraging it up with a spudger and pushing it in...NOTHING WORKS!
So, the problem is the computer doesn't even power on now. The battery indicator tells me that the battery is at full charge and when I plug in the power cord, it lights up green. Any ideas on what I can do? I'd really like this thing to work--my old DJ computer broke and I'm out of work until I fix this, so time is of the essence. Thanks!
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
Take a look at step #12 of this guide: MacBook Pro 13" Unibody Mid 2009 Upper Case Replacement
Make sure the lock is in the open position when inserting the cable. I do use Scotch tape to pull the cable in rather than trying to push it in.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Hm. My cable is as far in as the cable in that picture, yet my computer will not turn on. Any ideas what else I could try?
por
Adicionar a sua resposta
Edward Sapp será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 1,038
