Ir para o conteúdo principal
O Nexus S é um smartphone desenvolvido em conjunto pelo Google e pela Samsung, sendo o primeiro smartphone a utilizar o sistema operacional Android 2.3 "Gingerbread".
Nexus S Power Button Not Working
Hi all,
My Nexus S dropped into water the other day. After it's dried, I managed to boot it up by plugging in the power cable. Soon I realized the power button had stopped working. Other than that the phone seemed to work fine.
What should I do to get the phone fixed? Any ideas what parts I should replace and where can I find them? Thank you!
Jason
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Solução escolhida
Hi Jason,
I trust that you did a great job in drying the phone. I would make sure that the phone is completely dry inside. If the power button did not experience a physical damage, its malfunction could be related to water inside. And besides that, corrosion can occur.
I would open the phone and disassemble it as good as you can. Let every part dry. Also, take the motherboard in particular and lay it into isopropyl alcohol (90%). Let it stay there for about 10 minutes before you take it out of it. Then let it dry for about 2 days (e.g. next to a warm source like an air conditioning) before you put it back again.
Sure, water damage could have created an immediate shortcut. However, by following the steps above we might be able to solve the issue or - at least - are able to go from there.
Steffen
Esta resposta foi útil?
Pontuação 3
1 comentário:
Okay so what do i do if my power button just stops working?? never been dropped in water, never been dropped.. One morning my power button just started getting very sensitive then my phone tried to reboot and i haven't been able to turn it on since then. i've pulled the phone apart and there is no corrosion and no water damage.. Any help???
por
Réchauffement de réparation Samsung téléphone
Pontuação 0
Adicionar a sua resposta
Jason Lin será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 16
Últimos 30 dias: 34
Ao todo: 4,769
