Ir para o conteúdo principal
A Canon PowerShot é uma câmera de 5,0 megapixels com zoom óptico de 4x.
Zoom button does not self-center
My daughter dropped my A610 camera on the ground; minor aesthetical damages, but the zoom button is now a little hard to operate and when released, does not come back to center by itself anymore.
I dismantled the whole thing following the instructions to fix the speaker (outstanding instruction btw) hoping to find something fixable around the zoom button. When reaching step #9 a small coil spring (about 5mm or 3/16th of an inch in length) came loose falling on the table, and I couldn't see where it was coming from.
I was thinking that it might come from underneath the zoom button, I dismantled that bit but couldn't figure if it was coming from there. I also thought that it might be coming from the zoom potentiometer (or switch maybe?) fitted on the flexible PCB, but that potentiometer does not look damaged and is self-centering when I play with it with tweezers.
So long story short, I reassembled the camera without the spring, the zoom button is still hard to operate and does not re-center itself, and in bonus I'm left with that spring, not knowing what to do with it.
Any thought?
Marc B.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Solução escolhida
Hi Marc,
Take a look at this parts catalog of a PowerShot A620/A610. Pages 1, 4, or 5 might help you to find the place for that spring you are mentioning.
The issue with the zoom button might be related to the guide/guideway of the button. Maybe some of the plastic around the button was crushed a bit through the fall and is now hindering the button to find its way back to the end/released position.
Steffen
Esta resposta foi útil?
Pontuação 2
2 comentários:
Steffen,
Thanks for the hints, I think you are right on both counts, first: the plastic is indeed just a tiny little bit warped around the zoom button, preventing it to move freely. The trick to solve the problem was to loosen by about a quarter of a turn one of the three 6 mm screw holding the bottom of the battery compartment.
Second: the spring is not coming from the zoom button assembly, but from what I can read in the parts catalog it is "most probably" Item 9 of page 4, that is: a small spring used to ground the lens assembly to the body of the camera. There a video on YouTube that show how to totally dismantle the camera, honestly the steps required to reach that spring are a little beyond my patience, as the camera now work perfectly I will leave that spring out.
Many thanks for you help,
Marc B.
por
Hi Marc, thank you for your feedback. I am happy for you and am glad I could help. Steffen
por
No, that sping is not used for that. I have the same problem and I suspect that I need to add the spring to a specific location in order to have feedback from the zoom button.
Does ANYONE have a picture/guide on how we should assembly that area?
Pontuação 0
Adicionar a sua resposta
Marc será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 14
Ao todo: 467
