Damaged display power header whilst replacing hard disk drive
I've damaged the display power header pins on the logic board whilst replacing the hard disk drive, snapping one of the pins off (far right pin as you look at the header).
This is the header physically on the logic board and not the cable that plugs in to it. Neither is it the display data header/cable. The cable has a black plastic end to it and slots onto 6 metal pins: http://www.macpartsonline.com/922-9849-c...
Is it possible to get hold of the relevant header to replace via soldering, or am I resigned to a new logic board? If a new logic board is required can I use any 2011 logic board or is there a specific one for this machine?
Esta pergunta é pertinente?
6 comentários
What are the last three digits of your serial number? This will help to properly identify your computer and your logic board. Also post some images of your connector so we can see what you see.
por oldturkey03
If you could post a high res pict of the damaged connector that would help.
por lemerise
My serial number is DGKGC0H9DHJW EMC 2429
How do I post images here?
por Adam Smith
Thank you Yako, that part is exactly what I am looking for, unfortunately an engineer has identified another part that is damaged. It is immediately below pins 4 and 5 of this part (looking at it from left to right) and is labelled L9000 on the logic board. Any ideas of what this part is and where I can get it from?
por Adam Smith
Thank you oldturkey03, I can see from your diagram that it is a 250 ohm ferrite inductor, but is unclear what the ratings are for that component, i.e. the voltage, current rating, etc... Do you have any of this information?
por Adam Smith
Mostrar mais 1 comentário
