Red light comes on when I plug up my xbox?
When I connect my power cord up to my console the light goes from yellow to red on the power cord and the unit doesn't turn on.
Esta é uma boa pergunta?
Hi, most probably it is an issue with the power supply unit. Do u have access to another power supply unit, like one from a friend? Plug that in and see if that works ok. If that is ok then u would want to replace the psu. Did this happen after an intense session of gaming? Write back on what u did. Thanks.
Esta resposta foi útil?
I tried that one already saying results from the other power supply unit.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 539
Did you try anything else to fix the unit? I think I might also have that problem with my xbox 360.
por Leia
