Ir para o conteúdo principal
Apple iPad da primeira geração, disponível nas versões Wi-Fi e 3G com 16, 32 ou 64 GB de armazenamento.
267 Perguntas Visualizar todos
ipad 1st gen "not charging" problem, any fix?
hi there, i have an ipad 1st gen,, when i put charger in the socket it comes up with "not charging" i have tried 2 chargers with no luck the chargers i tried are the original ipad 10w charger, i have searched alot around, and i can see many have this problem, but do anyone know how to fix it??
regards
tonnie
Esta é uma boa pergunta?
Pontuação 1
1 comentário
The older large iPad chargers have known problem I had similar problem With three other charges I ignore the charges unused the simple charger underwear the problem went away I suspect the knockdown transformer inside these were overeating and failing but I don’t know yet. I’m trying to find the schematics of one of these charges. The other problem to be aware of is if you buy these charges on eBay and they haven’t been tested the person is likely to sell you a faulty transformer believing it to be okay so beware of this because you still got the same problem
por
Adicionar um comentário
5 respostas
Solução escolhida
tonnie, it is entirely possible that it does not charge because of a faulty battery. I suggest you start with that. Pick your iPad from the guide list and pick the one for your battery replacement. After that, reevaluate. At least that way you have a know good starting point for any further trouble shooting, should it be necessary. the error can also originate in the dock connector, the charging circuit, bad charging coil, bad charging diode or bad power management IC, but unless you have a known good point, it will be more of a guess than anything else. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 1
1 comentário:
thx, i replace battery before i try other solutions..
regards
tonnie
por
Pergunta mais útil
Ipad 1 does not charge with its charger. But any apple mac book can charge the Pad 1 through the USB connection. Somehow Apple had dropped support for this charger and want us to use a laptop or imac to charge the ipad 1. The logic of this operation is to encourage you to use iTune and sync.
Pontuação 4
I think faulty battery, It will charge if plugged into the PC/MAC however it takes a full day or or two to fully charge even though it still says "not charging". Charging sign comes on or off, so I do not rely on that. Mostly battery issue to me. Your average rechargeable batteries are only going to last 3-5 years anyhow.
Pontuação 2
I also had this problem and i fixed the issue all i did was take a clean tooth brush and some 70% rubbing alcohol and cleaned the charging port on the iPad as well as the USB Cable both ends of the usb cable because these three connecting points tend to get dirty over time so now it is charging hope this helps anyone with this problem.
Pontuação 0
May be you should try changing the chargeing port the screen or may be the battery because you know the iPad Is old
Pontuação 0
1 comentário:
@cboy88258 this is also a very old question. We really appreciate your input, but all of your suggestions have already been mentioned.
por
Adicionar a sua resposta
tonnie será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 9
Últimos 7 dias: 22
Últimos 30 dias: 77
Duração total: 37,933
