Ir para o conteúdo principal
The Game Boy released on April 21, 1989 in Japan, followed by North America on July 31, 1989, and lastly in Europe on September 28, 1990. It is characterized by a large grey casing and model number DMG-01.
Power but no startup sequence
I recently dug out my old gameboy, but despite supplying power, I do not get the logo block or sound when turned on. the led is red, though that just proves the led works.
I've tried with and without a cartridge, and with an 6V AC Adaptor, as well as four AA batteries that are fully charged.
I've checked for leaked capacitors, or acid damage from leaking batteries, but it looks like i've been lucky and there is no visible damage.
I've measured the voltage on the contrast, and I get a range of about 0.05 to 10V on the pot.
I couldn't find a voltage differential on the audio pot however. should there be one there yet if a startup hasn't occurred?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Pergunta mais útil
Steven Hodgson, could be a bit like looking for the proverbial needle in a haystack:-) I attached the power schematic for the GB and may be this will help you out. Check the caps on the DC-DC board. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 1
1 comentário:
thanks for replying oldturkey03. using the schematic i've checked, and the power is coming out at roughly those values. i checked the oscillator this morning and still running 4.19 MHz too.
por
Adicionar a sua resposta
Steven Hodgson será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 363
