lcd screen lit but remains plain white
My Lumix DMC-TZ5's LCD screen turns on, but while lit, only remains plain white. Other than that, it is fully functioning, as I can see the resulting photos taken when I open the SD card on the computer.
I was wondering what I could do to check if the problem is with the LCD itself or if it's something with the electronic components, that wouldn't be fixed by simply replacing the screen. I just don't want to buy a new screen, replace it, and then find out that the problem remains.
Esta é uma boa pergunta?
3 comentários
Useless I just need a simple solution not a risky operation in taking apart my £400 pound lumox tcz 10
por Hassan Nada
Same issue with mine, it has been a good camera up until now, but now the screen is generally white. Pictures are still good when I download to the camera, but hard to take them when you can't see or frame what you are taking. It will occasionally come back on, but 9 times out of 10 it is white. :-(
Panasonic should recall and do free repairs.... wishful thinking!
por Peter
Hello,
I have the same “white display” problem with mine. BUT this happens only with a SD card in. When I remove it, the display operates normally, and the camera works like a charm (but on its own very small memory).
I tried another (brand new and tested) SD card, but the problem remains the same.
The SD slot contacts looks ok, tough…
Any idea? Thank you…
por ouftimazette
