Ir para o conteúdo principal
MacBook Pro A1212 replace 1680 x 1050 with 1920 x 1024
Does anyone know if it's possible to replace a A1212 MacBook Pro 17 inch screen with a different resolution?
Currently i have 1680x1050 but i see a lot of 1920x1024 screens... Would it be possible to replace it. The video card supports the resolution on an external monitor.
Esta é uma boa pergunta?
Pontuação 0
3 comentários
I think may be one for Ben to answer. From what I find its not possible but I would go with what he says. Ralph
por
How can i contact Ben for this? I would imagine that the resolution might be fixed from the screen and not the interface. If so it maybe is possible... I keep on hoping :)
por
Adicionar um comentário
2 respostas
Solução escolhida
I haven't tried this, but theoretically it should be possible...
First, follow this guide to remove the display assembly.
Then, use steps 18-32 of this guide and some intuition to remove the LCD panel.
Finally, follow steps 33-38 of the same guide for the installation procedure.
Good luck! Please be sure to post the results.
Imagem de MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Display
Guia
MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Display Replacement
Nível de dificuldade:
Difícil
1 - 2 hours
Imagem de MacBook Pro 15" Core Duo Model A1150 LCD Panel High Definition (1920x1200)
Guia
MacBook Pro 15" Core Duo Model A1150 LCD Panel High Definition (1920x1200) Replacement
Muito difícil
Esta resposta foi útil?
Pontuação 3
2 comentários:
+ Ralph
por
And what were the results on this attempt?
Curious :)
por
sorry to be a bummer, but the apple logic boards have rom's that only recognize specific displays. If you install it, it will turn on but once the bootloader finishes and the OS starts to load, the screen will go black and you wont be able to brighten it
Pontuação 0
Adicionar a sua resposta
Questor será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 3,185
