Ir para o conteúdo principal
The GE Profile Tri-Temp is a free-standing water dispenser with an integrated chilled compartment.
48 Perguntas Visualizar todos
How I make the water cooler
is there a dial for coolder water
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Solução escolhida
Sol Kay, looks like there is no setting.
Water not hot or cold enough
Temperature limiter tripped. •Set the hot and cold power switches (on the back of the dispenser, if equipped) to the O (off) position. Wait 5 minutes; then set the switches to the I (on) position. Unplug unit for 5 minutes if model does not have separate power switches. Wait 30 minutes for water to heat or cool. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 3
2 comentários:
Water still not cold
por
Water not cold
por
IF your temp is set to coldest.. add ice. A cheap counter top ice maker would be perfect beside the cooler.
Pontuação 0
Adicionar a sua resposta
SOL KAY será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 23
Duração total: 6,443
