Ir para o conteúdo principal
The Chevrolet Cavalier is a compact automobile produced from 1982 to 2005 by General Motors.
driver headlight is dim
i have a problem with my driverside headlight.my daytime lights work until i put my switch on then my driver headlight is dim, when i turn my lights off my daytimes dont work and my headlight indicator light blinks.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
andre, check your light bulb to make sure that you have the right one installed. Check your wiring harness for a short. Check your connectors as well as relays for corrosion and make sure that you have proper ground connection.
Esta resposta foi útil?
Pontuação 2
2 comentários:
1st Step:
Test with an Instrument (Voltmeter),
if the correct or sufficient Voltage is supplied at the Bulb.
Measure at the 2 terminals of the bulb.
If your vehicle has a 12 Volt Electrical System, (DC)
the display at the Test-Instrument should read approximately 12 Volts.
Most "Multi-Meters" are able to measure DC-Voltages.
(Keep well and be kind to each other)
Klaus
por
Often the cause is a bad connection at the bulb-connection.
A bad connection is a Resistance for the electrical current.
This causes a Voltage-drop
and the bulb has insufficient voltage to light up fully.
por
Adicionar a sua resposta
andre será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 5
Ao todo: 1,490
