Ir para o conteúdo principal
Screen flickering when opening cover
I have a HP laptop. When the cover is half opened, the screen stays ok.
When I open it so I actually work with it, it flickers, turns complete white or black.
When pressing at the bottom of the screen, just above the logo, or when pressing the bezel at the bottom the screen is OK.
What could be the issue, how can ifixit?
Could it be an grounding issue?
There is a aluminium foil on the backcover, the screen is on top of some black foam. Should it make a electral contact?
Please advise
http://www.insidemylaptop.com/replace-br...
Esta é uma boa pergunta?
Pontuação 0
2 comentários
I took the laptop apart and measured the cable. It has no opens. But it could be a crack in the wire.
Also the cable is not a flatcable but soldered single wires with multicores. They are more difficult to crack, but ok..it could be.
Last thing I doubt about the broken cable..when I add pressure on the screen (when it was not apart) the screen worked perfectly. So now I have seen the connection I'm suspecting the connector itsel...or at least the connection between the connector and cable.
I order a cable after I'm sure it's not the connector.
Cable cost me around $10 if I order in US, I'm in Europe...cables varies from $25 to $70
Please correct me if my thinking sucks
por
Niels did you take a look at the connector? Have your tied to start it up with the display partially disassembled to see if pressure on the connector will fix it. If regular postage from the US to your country is cheaper than $15 I'll send it to you:-)
por
Adicionar um comentário
3 respostas
Solução escolhida
Niels, this most certainly sounds like a bad (shorted) LVDS cable. Get the service manual from here. The replacement display cable is readily available
● 656805-001 — For use only with computer models equipped with a FHD display
assembly
● 644362-001 — For use only with computer models in dark umber and steel gray finish
● 640423-001 — For use only with computer models in butter gold, espresso black, linen
white, Pacific blue, pearl pink, ruby red, and Sonoma red finish
It's not a terribly complicated job. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 1
1 comentário:
I took the laptop apart and measured the cable. It has no opens. But it could be a crack in the wire. Also the cable is not a flatcable but soldered single wires with multicores. They are more difficult to crack, but ok..it could be. Last thing I doubt about the broken cable..when I add pressure on the screen (when it was not apart) the screen worked perfectly. So now I have seen the connection I'm suspecting the connector itsel...or at least the connection between the connector and cable. I order a cable after I'm sure it's not the connector. Cable cost me around $10 if I order in US, I'm in Europe...cables varies from $25 to $70 Please correct me if my thinking sucks
por
Pergunta mais útil
Well that sounds like your having problems with the cable that connects the display to the mainboard, if your laptop is out of warranty then try to check the cable for rips or bends .
Pontuação 1
1 comentário:
por
Was there Any solution on this yet?? I have an issue with mine,that if you open it to a normal position, it won't turn on. But if I open it a quarter, the screen works fine.
Pontuação 0
Adicionar a sua resposta
Niels será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 18
Duração total: 17,998
