Ir para o conteúdo principal
The Apple Magic Mouse is a multi-touch mouse manufactured and sold by Apple Inc. It was announced and sold for the first time on October 20, 2009.
Mouse works intermittently, loose connection? Can it be fixed?
Follow a drop on a hardwood floor the mouse works intermittently. Will work, if connection established, for a while as long as not picked up and moved. On/off light either works, doesn't work, or flickers when trying to reconnect. Change of batteries does not change situation. Possibly a connection loosened by being dropped to floor. Can it be fixed?
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
1 resposta
Solução escolhida
mtuck205, yes, based on the symptoms you describe, it is possible and very likely that you have some loose component. Unless you open it up, use this teardown for some direction, we will never know.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
mtuck205 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 3,620
