Ir para o conteúdo principal
The Toshiba Satellite L300 was a notebook designed and sold by Toshiba that came with a version of Windows Vista. They were sold around May-June 2009 and while ineligible for the free 7 upgrade, time past and upgrades are unclaimable now, run 7 home premium well without upgrades mainly because of Vista's resource hog quality. Also known as Toshiba Satellite L300-04P (PSLB8C-04P01X).
20 Perguntas Visualizar todos
Why it goes off when plugged AC/DC adaptor
Please help..each time I plugged the Ac/Dc adaptor my laptop just goes off..bt it work only on battery mode
Esta é uma boa pergunta?
Pontuação 3
1 comentário
bob, have you checked your power supply to see if it is working properly? Check the voltages at the output connector and see if it is shorted.
por
Adicionar um comentário
2 respostas
Solução escolhida
bob, besides checking the power supply, remember that this series has issues with a bad capacitor. "The problem is caused by NEC TOKIN 0E907 Proadlizer PF/A Capacitor for High Speed Decoupling Device, witch is responsible of coupling or decoupling the CPU hi speed/hi power(ac plugged in) or low speed/low power(ac unplugged)." Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 2
1 comentário:
HI The link you provided is broken, I have a similar problem with my laptop, I'm curious about the bad capacitor. Can you provide more info? Or direct to where I can find info?
por
same problem with my laptop toshiba satellite m200. Can you show where exactly the location of that capacitor?
Pontuação 0
3 comentários:
@juls sacra 10 years later and people still reading this :-)
Anyhow, in order for us to try and find it on your motherboard, we will need to see your boards. Both sides of course.
So you can add it to your comment which I will convert to an answer. Once we have more detail, I convert it to its own question. In the meantime, add pictures of your boards to your answer.
Adicionar imagens a uma pergunta já existente
por
@oldturkey03 Sometimes I wish these prehistoric posts would be moved to some sort of archive.
por
@strongbow I guess for as long as there is still one person out there using this equipment, it's good to keep those old answers alive. After all, that is what we want. For people to use their devices as long as possible.:-)
It just gets difficult digging up repair information from 10 years ago :-)
por
Adicionar a sua resposta
bob será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Ao todo: 7,825
