thermal cable
Can anyone tell us what the part number is? That would probably help with the search. I can't find this part anywhere!
Esta é uma boa pergunta?
The correct thermal cable depends on what brand of hard drive you are using. The hard drives for models 2009 and above use an Apple priority thermal sensor and off the shelve hard drives will have run away fan issues. What are you trying to do?
Esta resposta foi útil?
Can l use w/out cable?
Sure, if you don'=t mind a run away fan,
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 341
