Ir para o conteúdo principal
Versão renovada do iPhone 3G com velocidades de processamento mais rápidas. O reparo deste dispositivo é semelhante ao do 3G e requer simples chaves de fenda e ferramentas de abertura. Modelo A1303 / 8 GB,16 GB ou 32 GB de capacidade / Parte traseira em plástico preto ou branco.
It said iPhone disabled connect to itunes
It told me to unlock it
Esta é uma boa pergunta?
Pontuação 60
10 comentários
my iphone3gs is lock
por
My iPhone 4 is lock
por
I have a A1303 Apple IPhone and it is locked on Connect ti iTunes and showing USB CONNECT TO LAPTOP. Before I open it, it state iOS6 ?? I have held both the home and power button down for 10 sec after turning the iP off and releasing the power button after 10 secs but nothing happens.
por
i phone is disable to connect itune
por
iphone is disabled
how i do open this lock
por
Exibir mais 5 comentários
Adicionar um comentário
3 respostas
Solução escolhida
toby gray, put your iPhone in DFU mode and Restore with iTunes:
Connect your iPhone to your computer
Turn your iPod off
For 10 seconds, hold both the Home and Power buttons
While still holding the home button down, release the power button only Continue to hold the home button down for an additional 10 seconds. After the dialog box explaining that the iPhone was found in recovery mode has been closed, restore your iPhone. Bad part with this is that you are going to erase the information that has been collecting on your phone since the last backup. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 16
4 comentários:
thank you so much for the helppp!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! it took me so long to find the answer and i looked it up on google and this website popped up and it was soo so so so helful, agian THANK YOU!!!!!
por
you can also just power off the device and hold home button down as you connect it to force it into recovery mode, and then restore with itunes... again all data will be lost , this is easier than DFU mode
por
thank you soooooooooo much!!!
por
tnakyou so much for your help
por
Connect your iPhone to a windows laptop or computer.
If that doesn't work then try something else.
I really hope this works for you guys because it definitely worked for me.
Pontuação 5
Turn your iPod off
Pontuação 1
2 comentários:
I am trying to unlock my mom's iPhone 4. She passed away a year ago. I tried different things and now it says "iPhone disabled connect to iTunes ". Tried that and did not work! I really need some help here. Trying to get this done and give it to a cousin who is down on his luck and needs this phone. Thanks in advance!!
por
It's disgusting that apple did this, such a critical issue with data stored getting lost. I surprised
por
Adicionar a sua resposta
toby gray será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Ao todo: 36,564
