Ir para o conteúdo principal
Optical Drive hardware eject
I have an A1261 Core2duo 17" MacBook Pro which died due to a faulty logic board a few days ago. There's a dvd stuck in the drive which I want to get out. What are my options? It's out of warranty, so I don't mind tearing it down. Is there a hardware eject for the optical drive?
I'd also like to know if you guys stock logic boards for my laptop model... its a 2.5ghz core2duo 17" mbp
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
Here is the guide for opening a drive to remove a disk. You must first remove the drive for the computer. I'm still looking for that guide for your computer. Ralph
Optical Drive Disc Removal Technique, or Foreign Object Removal
The best I can fin is the 15" MBP but it should give you a good idea. Ralph
MacBook Pro 15" Core 2 Duo Model A1211
Esta resposta foi útil?
Pontuação 3
2 comentários:
The right link +
por
Thanks for that. I got the disk out using the credit card trick :) didn't actually think it would work, but it did :P thanks anyways
por
Adicionar a sua resposta
Nikhil Venkatesh será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 14
Ao todo: 1,933
