Ir para o conteúdo principal
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
lcd display model number and replacement
i wanted to replace my lcd panel.
my macbook has lcd panel no. : lp133wx2
wanted to know if i can fit an lcd with
panel no. : lp133wx3 to my macbook.
will it still work.
thank you
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Sagar, get the datasheets for both of the panels. The LP133WX3 is here and the LP133WX2 from here. There seems to be a minor difference with the LVDS connector, which may be negligible. The lp144wx2 uses a I-PEX 20474-030E–12 and the lp133wx3 a I-PEX 20474-030E–1# connector. The pinouts are identical.
Esta resposta foi útil?
Pontuação 1
5 comentários:
ok. thank you.
but do you think the display would work properly
por
Yes I do. If you read the data sheet and compare the two panels, they do appear identical.
por
thank you very much.
i will let you know if it worked properly after i
install the lcd this weekend.
thanks again
por
It worked
Thanks
por
That is great. Congratulations on a great fix. Thanks for accepting my answer.
por
Adicionar a sua resposta
SAGAR será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 13
Ao todo: 475
