Ir para o conteúdo principal
Quinta Geração do Iphone. A Reparação deste dispositivo é correta, requer ferramentas especificas e paciência. GSM/CDMA/16, 32 OR 64 GB/Black or White.
2193 Perguntas Visualizar todos
Vibrate Switch Stripped Screw Help
Please refer to the following manual for the screw I am referring to:
iPhone 4S, Headphone Jack Cable, Step 32
The screw head is stripped. Im looking for a way to get this thing out and replace it. Drilling and tapping is out I assume because its so dang small. Any help would be appreciated.
Thanks
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
If you hold the back of the phone and push up while pressing down to loosen the screw. A small flat tip precision screwdriver typically works.
Superglue will work. I always prefer the Gel type.
I keep a bottle of ScrewGrab in the shop, you can find it on Amazon.
Esta resposta foi útil?
Pontuação 2
1 comentário:
You guys rock. Thanks for the tips. Ill give them a shot.
por
You could try using super glue or a similar epoxy to bind it to your screwdriver, then replace the screw with a new one. I suggest something along the lines of JB Weld or Loctite. As it's a small area to work with I suggest applying the epoxy to the screwdriver first, not the screw to prevent overflow/spilling onto nearby components! Good luck!
Pontuação 0
Adicionar a sua resposta
Ryan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 337
