Ir para o conteúdo principal
How do I make this computer respond?
when booting this mac it only goes to the apple screen and had the loading ring..it will not go any further.. what should i do?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
Reboot from the original system installation disk ( C key ). Go to the second screen pull down menu to Utilities > Disk Utilities and see if you can run the Disk Repair. Let us know your results please.
Esta resposta foi útil?
Pontuação 3
3 comentários:
So I've tried that and at one point it wouldnt eject the disk. It will not turn off using the power button. It just does what I stated before. Please tell me it's something I can fix myself with your help. Thanks!!
por
Did you get to disk utilities? Would it repair the drive?
por
No. It stays on the apple screen with a spinning loading cirlce it will not respond to the disk (c key). Honestly i think it would continue to stay on that screen til the battery dies. Is there anything else i can do?
por
Adicionar a sua resposta
kim será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Ao todo: 232
