Ir para o conteúdo principal
Um tablet desenvolvido pela HP em 2011 que roda a plataforma webOS. Possui uma tela de 9,7" e está disponível em 16 ou 32 GB. O reparo é simples, mas requer tempo e persistência.
Battery Icon with question mark (?)
My HP touchpad is out of warranty. When I try to power it on it shows a battery icon with question mark in it. When it is connected to a charger the light flashes on the center button. I have tried all solutions posted on the web, with different button combinations, leaving it on charge for more than a day, using different cables, trying to leave it connected to a computer, etc. Everything brings back the battery icon with question mark and cannot do anything more.
Connecting to a computer with USB, makes the center button lights to flash, but cannot access the file system thru USB.
I thought changing the battery, but not sure if that will fix the issue.
Is there a way to reset to factory defaults?
Please let me know if there is anyway to fix this.
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
7 respostas
Solução escolhida
Here's how to replace your DEAD battery: Substituição da bateria do HP TouchPad
Esta resposta foi útil?
Pontuação 6
It is more than likely not the battery, but that it is 'bricked' due to corruption of the boot-up firmware. Many people have had the issue, including myself, and resolved it by the methods at this link:
http://rootzwiki.com/topic/38786-tpdebri...
If this works for you, then thank all the people who worked to develop a solution especially 'jcsullins'!
Pontuação 2
In french the solution is here:
http://lmorel3.fr/2014/05/debrickez-votr...
Pontuação 2
my talet still has a question mark on the energy symbol i try all the website in the whole world i think.but It did'nt work. i try to charge It on the computer It did'nt work, i bought a new charger It still did'nt work. now i'm just bored at home
Pontuação 1
1 comentário:
IF you are bored, you should get a new iPad.
por Compartilhar
Resolve this issue...
Pontuação 0
Hello I got a LG phone and when I turned on I saw the question mark on the battery I plugged In for a hour I stayed off it I plugged in for the whole night WHAT SHOULD DO????
Pontuação 0
1 comentário:
did you ever figure this out? i have same problem email me skram84@gmail.com
por Compartilhar
My new stylo 5 phone has its original charger it shows a question mark when plugged in. What can I do to fix it?
Pontuação 0
Adicionar a sua resposta
Rani será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 41
Ao todo: 47,262
