Ir para o conteúdo principal
The Samsung Epic 4G is the Sprint model for the Samsung Galaxy S Series.
2 Perguntas Visualizar todos
Pergunta encerrada
The microphone only works when using speakerphone .
I have a samsung epic 4g. Yesterday the ribbon cable for the touchscreen decided to break. It just so happens that I had an extra phone as a result me getting even with my phone insurance company (another story). Rather than just activating the other phone I wanted to device to remain configured the same as it was, so I opened them up and swapped the mother board etc. This appeared to work but when making a call I noticed no could hear me. I could hear people, but the same was not true. I tried putting what I assumed to be the microphone ( the piece at the bottom with the speaker that the white antenna cable connects to) from the old phone into the new phone housing containing the guts from the old phone. Still no functioning microphone (I tried using a voice command on the phone just to check it wasnt something to do with calling). I did notice however that when the phone is on speakerphone everything functions normally. Help please. I thought I had this figured out, but it appears I do not.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Hi i have info that might help you, phone are equipped with two microphone, one is for the ear speakers and another is for when you switch to the speaker phone, when you use the ear speaker the mic on the bottom is activated and when you change it to loud speaker it will switch to the top microphone, if you were to look carefully around your phone you will realized that there are two similar pin size hole usually located one on the top and one on the bottom and that is your mic hole, i have observe alot of phones with two mic holes, so most likely your bottom mic is faulty while your top speaker is still working, that explains why you are facing with this issue, so focus more on the bottom mic, cheers! hope this helps!
Esta resposta foi útil?
Pontuação 0
change charging jack
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 10,895
