Ir para o conteúdo principal
Versão renovada do iPhone 3G com velocidades de processamento mais rápidas. O reparo deste dispositivo é semelhante ao do 3G e requer simples chaves de fenda e ferramentas de abertura. Modelo A1303 / 8 GB,16 GB ou 32 GB de capacidade / Parte traseira em plástico preto ou branco.
1500 Perguntas Visualizar todos
Pergunta encerrada
Power button not working after flex cable replacement
Hello,
I have an Iphone 3gs that the power button didn't work so, I replaced the flex cable thinking that it was bad. Wow, what a feat! I got the phone re-assembled and it still does not work. All of the other buttons, volume up/down, mute switch, headphone jack, work as they should. This is the same behavior that it was doing before I replaced the flex cable. Is there something on the logic board that is causing the issue? I don't want to go through the painstaking task of putting in another cable. Is there something else that I can try?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
are you sure it makes good contact? sometimes i have to bend the 2 legs a little
Esta resposta foi útil?
Pontuação 0
1 comentário:
Yes, I double checked the connections. Like I said, the volume buttons, headphone jack and the mute switch all work just fine. It's just that darn power switch.
por
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 485
