Ir para o conteúdo principal
O Palm Pre é um smartphone multimídia projetado e comercializado pela Palm, com uma tela tátil e teclado deslizante.
I am unable to here voice in palm pre plus
When i answer any call unable to here voice when i switch it to loudspeaker i am able to here, that is my phone problem.
can any one solve the my problem ASAP.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
surya, sounds like a blown earpiece speaker. Check this video for instructions. For further repair guides check on here. Hope this helps, good luck
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
I've run into this on my Pre+ and Pre 2 and often it's the sensor in the headphone jack not working correctly. The phone thinks a headset is still plugged in even when one isn't. This usually happens to me after I've had headphones or a cable plugged into the phone.
Short of taking the phone apart to clean or repair the piece in the headphone jack, I usually plug and unplug something into the jack until it manages to fix itself. I'll try playing music using the music player: if it's playing but you don't hear anything out of the speaker, the phone still thinks a headset is plugged in. Once the headphone sensor correctly identifies nothing plugged in, you will hear the music on the phone speaker.
Hope this helps!
Pontuação 2
Adicionar a sua resposta
surya será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 20
Ao todo: 781
