Ir para o conteúdo principal
Google-branded tablet with a 7" screen. The device needs only prying tools and screwdrivers to fix. Model number: ME370T.
Pergunta encerrada
Changing of flash memory
Hi do you have any tutorial on changing the flash memory for nexus 7?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Tan Yong He, the memory is a BGA IC and soldered to the logic board. You can only change it if you have a reball setup, the right stencil and the right memory. Here is the information on the memory.
Esta resposta foi útil?
Pontuação 1
3 comentários:
is there anywhere that helps to change the flash memory?
por
what happened that you need to change your memory?
por
Can you give specific part number of Flash memory from that list?
por
The chip is the Kingston KE44B-26BN/8GB 8GB flash
However, if this chip is changed will this brick the device? I.e. is the OS stored on the (removed) flash chip, or is this flash just for user files storage?
Pontuação 0
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Ao todo: 2,767
