Ir para o conteúdo principal
iPhone de quarta geração lançado em 2010. O reparo é simples, mas o vidro frontal e o LCD devem ser substituídos juntos, como uma unidade. GSM / 8, 16 ou 32 GB de capacidade / Modelo A1332 / Preto e Branco.
2375 Perguntas Visualizar todos
I need a battery connector bypass tutorial
I am looking for anyone with any info on how to EXACTLY walk me through a battery connector bypass. Either, using bypass wires or another method. Any way that's most effective. I am not interested in sending my phone to someone, or interested in a person telling me that his/her shop sees that all the time and can fix it for me. Can anyone help me? I have a soldering kit and some soldering experience.
Esta é uma boa pergunta?
Pontuação 4
3 comentários
I do understand what you are saying, just trying to understand it a bit better. you need to bypass the original connectors, why? How far away from the original connectors do you have to be?
por
My battery connector has disconnected from the board. I tried to solder it back on, but it looks like it needs new pads.
por
U guys are doing great work here I live it. And I I'll want u to help me solve my infinix x600(note2) battery connector it has disconnected from the board plz help
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Caleb, bridge the points with the smallest wire you can find and use the image as a guide. Reroute any wire so that they are not in the way with the re-assembly. Take a look at this video as well as on here. Both videos show it very well. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 3
7 comentários:
It was of great help!! Thank-you so much!!
por
Claudio, you are welcome. good luck.
por
Thankyou phone working again
por
Amazing, love u, ur my lady luck
por
Thx for the perfect answer had 1 month issue with mine iphone finnaly fixed it with the help of your guide ill contribute on this site with every knowledge i have
por
Exibir mais 2 comentários
Adicionar a sua resposta
Caleb será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 16,730
