Ir para o conteúdo principal
Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745 Perguntas Visualizar todos
May have accidentally bent this cable - What does it control?
Just installed a SSD in my MacBook Pro 13" Unibody Mid-2009. I also chose to remove my optical drive and install a hard drive in its place. While doing the installation, I had some trouble re-inserting a cable, and fear that I may have inadvertently bent it slightly. It's a large/fairly thick cable near the fan on the motherobard; I had to remove it in order to access a screw that's underneath it.
The machine *appears* to be working fine, everything I've tested so far (sound, wifi, etc.) appears to be working as it should. What is this cable for (i.e. is there something I can test to see if it's working or not)?
Picture of the cable I'm talking about is below. Thanks!
Esta é uma boa pergunta?
Pontuação -1
1 comentário
Yup, that's the iSIght cable all right. Thanks. Luckily I didn't damage mine; my iSight still works perfectly. Thanks for your answers!
por
Adicionar um comentário
2 respostas
Solução escolhida
dburr, I wonder if it is the camera cable. It might be more visible if you could zoom out a bit and give more of a location. Of course, I am not a Mac person, so I could be way off:-)
Esta resposta foi útil?
Pontuação 3
That is the camera cable.
Have a look at step 10 of this guide:
MacBook Pro 13" Unibody Mid 2009 Logic Board Replacement
I just had a rough time unplugging mine while removing the logic board.
Pontuação 2
Adicionar a sua resposta
dburr será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 566
