Ir para o conteúdo principal
Quinta Geração do Iphone. A Reparação deste dispositivo é correta, requer ferramentas especificas e paciência. GSM/CDMA/16, 32 OR 64 GB/Black or White.
2180 Perguntas Visualizar todos
Pergunta encerrada
iPhone 4s and 4 screen compatibility
I have both an iPhone 4 and an iPhone 4S. the 4S has a shattered screen http://imgur.com/FQuML and the 4 has a good screen (both GSM)
Are these two compatible? can I replace the 4S screen with the iPhone 4 screen?
Thank you!!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Citronex, this has been previously discussed. Check this answer and you will find more if you search the Answer section. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 3
In conclusion, 4 display can be connected to 4s. I am using like this, now.
But you need some trick.
iPhone 4 display assembly can not bind to 4s frame directly because 4's display assembly binding legs location are not matched to the 4s's location. You can tear the white(or black) plastic frame of 4 display assembly. Binding legs are attached to this assembly's plastic frame. If then, you can connect 4 display to the 4s body.
Pontuação 1
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 4,377
