Ir para o conteúdo principal
The Compaq Mini 110 is smaller than a traditional laptop making it very portable. It's great for doing work on the go and it's easy to sync with your main computer making the Compaq Mini a great companion.
14 Perguntas Visualizar todos
My Compaq Mini 110 says there is a missing/corrupt file
When I turn on my Compaq Mini 110, it says "Windows could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM". It says to attempt repair by starting Windows Setup CD-ROM and select 'r' at the first screen. I don't have a cd-rom and there's no place for it.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Pergunta mais útil
Tori, you might want to try this "There are two ways to access Roxio BackOn Track to recovery the computer, either through the boot menu, or through the Windows Start menu.
Access Roxio BackOn Track using the boot menu if computer cannot access Windows.
You can use the boot menu to restore your computer to a previous working state or to return the computer to the state it was in before the last time it was restored.
Press the power button to turn on the HP Mini.
Press and hold down the f6 key to open the Windows Boot Manager, use the down arrow key to select Roxio BackOnTrack , and then press the enter key to open Roxio BackOn Track.
Access Roxio BackOn Track using the Windows Start menu if computer can boot into Windows.
If you can access Windows, in addition to restoring your computer to a previous working state, you use other options, such as Disaster Recovery.
Click Start , All Programs , Roxio , BackOnTrack , and then BackOnTrack Home to open Roxio BackOn Track." more information about that on here. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Im pressing f6 but it doesnt do anything
por
Adicionar a sua resposta
Tori será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 1,968
