Ir para o conteúdo principal
iPod touch (2nd Gen) screen problems.
Hi,
So after a few falls my screen has a few cracks. The "touch" part of the low part of the screen isn't working (which means i can't unlock the ipod by sliding the unlock button). If i understood correctly from what i've read, i need to change the digitizer as shown here
iPod Touch 2nd Generation Front Panel Replacement
My question is, would it work if i use this for example?
http://www.ebay.co.uk/itm/IPod-Touch-2nd...
The ipod is not in great shape(i also spilled some beer on it the other day :P ) could the hardware inside the ipod be damaged?
Thanks a lot
Esta é uma boa pergunta?
Pontuação 0
4 comentários
Thanks oldturkey,i'll order it and see what happens. I'll feel kinda stupid if this works,i've been going around with a broken and semifunctioning screen for months now:P
Thanks again.
por
Sounds good, let us know how it turns out ;-)
por
Sooo, the digitizer arrived, i managed to change it and everything works! The problem is that my plastic frame broke and my screen is kinda loose :P I have to buy a new frame i guess..
One question though, about the home button. The digitizer i bought didn't have a home button,so for now i just put the piece with the home button of my old frame. If i buy a new frame,will i be able to put the home button? Can i buy just the frame,or it comes only with a digitizer? Or should i just put some "glue" to hold the screen in place?
Thanks again a LOT,i never though i would see my ipod fully working:P
Before and after
http://i.imgur.com/MAvCE.jpg
por
All those questions are depending on where you purchase it, and what the seller offers. I always try to get a panel as complete as possible. It is time saving and a lot easier. So, do some good searching and see what the individual sellers offer.
por
Adicionar um comentário
1 resposta
Solução escolhida
John, start by replacing the digitizer. If only a certain section is unresponsive, it is very likely that it is the digitizer that has failed. Yes, the part you listed will work. Remember the iPod is a bit of a PITA to work on. Follow the guides, and clean your iPod with isopropyl alcohol to remove the beer stains ;) Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
John será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Ao todo: 825
