Ir para o conteúdo principal
Guias de reparo, manuais e ajuda na resolução de problemas para Xbox 360. Aqui você recebe tudo o que precisa para consertar por conta própria o seu Xbox 360.
Xbox Error Codes E74
I've been looking everywhere on the web , stores , people everything , but i can not find anyone that knows how to fix E74 , all I can find is to over heat your xbox but that can ruin my xbox even more , please help me fix my xbox I don't have the money to go out and buy another one.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
Pergunta mais útil
Chris, " E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. If the cable is known to be working then there is a 90% chance it's a scaler chip problem (the "ANA" or "HANA" chip connected directly to the AV cable) in rare cases it is the GPU." check on here for more info on that. What you have is basically a variation of the RROD. in your case it is not the CPU/GPU that is giving the error, but the HANA chip. A reflow of this chip might resolve it for a while at least. A permanent fix would be to reball the chip. check on herefor some idea on how to reflow and do stay away from purposely overheating your console. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 1
Overheating the xbox should always be a last resort. If you keep getting error e74 try this http://howtofixstuff.blogspot.ca/2013/08...
Pontuação 0
Hello :)
Thank you so much for your help. I am gonna try this and see how it works :)
Pontuação 0
1 comentário:
Hello !! :) I have been playing pass three hours. It was totally working fine. Hopefully it's gonna last long.
I gotta give credit to this guy really. RickTheElectronicGuy
from youtube.
Cause I could fine any heat gun but got the idea baking from cooker from him.
Working totally fine so far... lol
Have a great time guys ;)
por
Adicionar a sua resposta
Chris será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 27
Ao todo: 12,520
