Ir para o conteúdo principal
The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
318 Perguntas Visualizar todos
Dryer door keeps opening
The door keeps opening causing the dryer to quit. How can I keep the door from opening. It is not overloaded, but the clothes on the inside keeps pushing the door slightly open causing the dryer to quit.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
4 respostas
Pergunta mais útil
I also have this problem. pushing the top of my dryer door closes it again so I can start the load once more. it will continue to randomly pop open by itself. funny enough my washing machine was doing the exact same thing!!!!!!! It was dumping an entire load of waster on my floor, sometimes several times in a day with out me even doing a load of laundry. seems like the latches may be weak?
Esta resposta foi útil?
Pontuação 1
Wade Wesley, check your door latches and make sure they do have enough tension. You can get replacements from here. Hope this helps, good luck.
Pontuação 0
you should also check the exhust hose for clogs both where it connests to the dryer and at the exit of the house,,,any back pressure could be pushing on the door helping it pop open
Pontuação 0
I also have this problem. I bought new latches because it looked like the other latches' plastic was worn out.
I put it back together and it still won't latch well.
I'm really frustrated.
Pontuação 0
Adicionar a sua resposta
Wade Wesley será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 13
Duração total: 10,314
