Ir para o conteúdo principal
My iPod wont charge
Some fruit leaked in my bad and went into the bottom of my ipod where i connect it to my speakers or to charge, i'm off on holiday soon and really want to take it with me, i dont want to buy a new one as its specially engraved...can you help?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Sophie Paxman, you should treat it like any other liquid damage. This means that you have to take it apart, and clean all the parts with isopropyl alcohol 90% or better. Use the guides from here to work on your iPod. Of course, the first thing you could try is to clean the dock connector thouroughly with the isopropyl alcohol. Make sure that none of the pins is bend, broken or has debris on it. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Sophie Paxman será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Ao todo: 937
