Battery Will Not Hold Charge
The laptop will not hold a charge or will not charge at all.
Faulty Battery Connection
If the laptop is not charging at all, shut down the laptop, unplug the power cord, remove the battery from the laptop, press and hold the power button for 30 seconds and then release it. Then place the battery back into the laptop and plug the charger into the laptop. Turn on the laptop and it should begin charging.
Outdated Battery Driver
Make sure the battery driver is up to date. You can do this by going to Lenovo’s support website and download the latest version of the battery driver.
Battery Is Broken
The battery is broken and needs to be replaced. Here is the guide for the battery replacement:
Lenovo IdeaPad 110 Touch-15ACL Battery Replacement
Device Does Not Display An Inserted USB
After plugging in an external device, the computer does not read it.
Unrecognized Hardware Changes
Search for “Device Manager” in the windows search bar and select it. Select the PC icon and view the action tab. Click “scan for hardware changes” and see if the laptop recognizes the USB device.
Faulty USB Port
Make sure the laptop is turned off. Next, you will remove the motherboard and desolder the USB port. Replace the USB port and solder it to the motherboard. Here is the guide to remove the motherboard of the laptop:
Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement
Computer Loading Slowly / Freezing on Screen
When operating laptop, it loads slowly and/or the screen freezes.
Too Many Files in “Temp” Folder
Make sure all applications are closed. Press the “Windows” key and the “R” key and a window will appear. Type %temp% and click “OK”. Delete all the files in this folder. Some files may not be deleted and you may ignore these files.
Dust in Laptop’s Fan
Make sure the laptop is turned off. Next, remove the Lenovo IdeaPad 110 Touch 15ACL of the laptop and clear the dust out of the fan. Here is the guide to remove the Lenovo IdeaPad 110 Touch 15ACL of the laptop:
Lenovo IdeaPad 110 Touch-15ACL Back Case Replacement
Computer Is Unmuted, But No Sound Is Produced
There is no sound coming from the computer speakers.
Faulty Sound Driver
Make sure the sound driver is up to date. You can do this by going to Lenovo’s support website and download the latest version of the sound driver.
Incorrect Selection of Output Device
Make sure there is a speaker icon at the bottom of the screen, Make sure the volume is not muted, Right-click the speaker icon, then select Open Sound settings, Go to the Output section, confirm that the computer speakers are selected within the Choose your output device drop-down, increase the volume if the volume is low.
Laptop’s Speaker is Broken
Replace the Laptop’s Speaker. Here is a link to the guide for speaker replacement:
Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement
Computer Is On But Screen Is Black/Touch-Screen Not Working
When powering on computer, the power button is lit up as if the computer is on; however the laptop screen is black and/or the touch-screen is not working.
Laptop Does Not Have Sufficient Power
Check to make sure that the computer has sufficient power to operate the display via lights or sounds from the computer, if not then see LENOVO’S support for “No Power Issues” page.
BIOS Screen Is Not Displaying
To check if the BIOS screen can be displayed, turn off the laptop and wait 30 seconds. Next, turn on PC and immediately press “fn” key and F2 key, (this may take several attempts to be successful). The BIOS screen should be displayed.
Screen Is Broken
The laptop’s screen is broken and needs to be replaced. Here is the link to the guide for the screen replacement:
0 comentários
