Ir para o conteúdo principal
Lenovo IdeaPad 110 Touch-15ACL Screen Replacement
O que você precisa
  1. Lenovo IdeaPad 110 Touch-15ACL Screen Replacement, Back Case: passo 1, imagem 1 %32
    • Remove the thirteen 6 mm Phillips #0 screws.
  2. Lenovo IdeaPad 110 Touch-15ACL Screen Replacement: passo 2, imagem 1 %32 Lenovo IdeaPad 110 Touch-15ACL Screen Replacement: passo 2, imagem 2 %32
    • Use an opening tool to gently disconnect most of the clips on the back panel.
    • DO NOT force the panel out towards the optical disk drive.
  3. Lenovo IdeaPad 110 Touch-15ACL Screen Replacement: passo 3, imagem 1 %32 Lenovo IdeaPad 110 Touch-15ACL Screen Replacement: passo 3, imagem 2 %32 Lenovo IdeaPad 110 Touch-15ACL Screen Replacement: passo 3, imagem 3 %32
    • Pry the disk drive away from the center of the laptop.
    • Don't worry about any screws since we already removed the screws that are associated with the drive.
    • Once the drive is removed, remove the one 2 mm Phillips #0 screw that is now exposed.
  4. Lenovo IdeaPad 110 Touch-15ACL Screen Replacement: passo 4, imagem 1 %32 Lenovo IdeaPad 110 Touch-15ACL Screen Replacement: passo 4, imagem 2 %32 Lenovo IdeaPad 110 Touch-15ACL Screen Replacement: passo 4, imagem 3 %32
    • Unclip any of the remaining clips and remove the back panel.
  5. Lenovo IdeaPad 110 Touch-15ACL Screen Replacement, Battery Replacement: passo 5, imagem 1 %32
    • Remove the four 6 mm Phillips #0 mounting screws.
  6. Lenovo IdeaPad 110 Touch-15ACL Screen Replacement: passo 6, imagem 1 %32 Lenovo IdeaPad 110 Touch-15ACL Screen Replacement: passo 6, imagem 2 %32 Lenovo IdeaPad 110 Touch-15ACL Screen Replacement: passo 6, imagem 3 %32
    • Detach the wire connected to the motherboard and remove the battery assembly.
  7. Lenovo IdeaPad 110 Touch-15ACL Screen Replacement, Screen Replacement: passo 7, imagem 1 %32 Lenovo IdeaPad 110 Touch-15ACL Screen Replacement, Screen Replacement: passo 7, imagem 2 %32 Lenovo IdeaPad 110 Touch-15ACL Screen Replacement, Screen Replacement: passo 7, imagem 3 %32
    • Open the laptop so the screen is facing you.
    • Use a pick or spudger to detach the clips around the screen holding the bezel in place.
    • Remove the bezel.
  8. Lenovo IdeaPad 110 Touch-15ACL Screen Replacement: passo 8, imagem 1 %32 Lenovo IdeaPad 110 Touch-15ACL Screen Replacement: passo 8, imagem 2 %32 Lenovo IdeaPad 110 Touch-15ACL Screen Replacement: passo 8, imagem 3 %32
    • Remove the four 3 mm size Phillips #0 mounting screws.
  9. Lenovo IdeaPad 110 Touch-15ACL Screen Replacement: passo 9, imagem 1 %32 Lenovo IdeaPad 110 Touch-15ACL Screen Replacement: passo 9, imagem 2 %32 Lenovo IdeaPad 110 Touch-15ACL Screen Replacement: passo 9, imagem 3 %32
    • Carefully detach the display cable that attaches to the display.
    • There may be a piece of tape covering the connection. Be sure to preserve this if possible—it ensures a proper connection to your display.
Conclusão
Clark Beuckman
Membro desde: 02/22/22
544 Reputação
Autoria de 5 guias
Equipe
Clemson, Team 2-3, Hunter Spring 2022 Membro de Clemson, Team 2-3, Hunter Spring 2022
CLEM-HUNTER-S22S2G3
Membros da 5
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 146
